Drifter Design
thumbs pic463a Drifter Design
Thought you might like this picture. This is the 14' Drifter built by Tom Holt. Thigh braces and anchor system by Brett Wilson. From the Green River in Utah, Sept. 2003. Mother-in-law rapid. Note the canoe wrapped around the rock near the back of the boat.
1 Photos
thumbs pic728c Drifter Design
Gentlemen, I thought you folks might like a few pictures of a boat I built from your plans. It's the 14' version of the Drifter. I use it for fishing in the bays around my home in Kodiak, Alaska. I used red oak for the stringers, chines and sheer clamps. The little boat is small enough to be launched and recovered from numerous beaches around the island. The design does well in small surf and in light chop. Driven originally by an 87 lb thrust trolling motor, it now a 3 horse outboard. Even in Alaska, the construction costs were only $1100.00. This was my first attempt at boatbuilding and if I thought there were a market for these boats, I would retire and build them for a living! Enjoy!
P/S The line over the port side is connected to a freshly caught 87 pound halibut!
Terry L. Michalski
4 Photos
thumbs pic555l Drifter Design
Hello Barry, here are a few photo's of my Drifter 16. I included a couple of construction photo's as well as some of the finished product. I altered the plans a bit to set it up for fly fishing. Thanks for the Plans!
-Cam
13 Photos
thumbs pic340b5b Drifter Design
Subject: 16' Drifter picture Date: 10/14/02
Here's my 16 ft. drifter. Finished, floating, fishing off the Kenai river this fall 9/2002). Sorry took so long to get a picture into you. The rower seat is actually a large cooler and pad (economical spacesaver especially for long trips) that's adjustable (2' worth) up and down the boat via holes drilled for 9/16" all-thread that serve to lock it into place. Like the rower's seat, the rower's foot rest is adjustable as are the oar positions - all in 6" increments. This accomodates any rower's arm/leg length. Would not change anything. The front bench has sliding, overlapping oak panel doors accessable from front or back for items like tackle, life jackets, etc. Modified the transom a little so have extra seat there which has a hinged top for more storage. Ran conduit containing anchor rope from a foot brake to the transom and works great. Have fished it at all summer and it is a pleasure.
8 Photos
thumbs pic85 Drifter Design
Subject: Drifter 16 from Holland
Date: Fri, 20 Aug 1999 13:07:43
I finished my Drifter 16 feet. It is fitted with seats along the sides in front. I met with a problem of what type of motor to hang on. It should have been a Yamaha 9.9 long tail. I did with the ultra long tail. The picture is with another motor....
Boudewijn Binkhorst
1 Photos
thumbs pic92 Drifter Design
Subject: Another dory pic. Date: Fri, 10 Sep 1999 17:39:46 From: Bocole@aol.com
Thanks for the interest in my dory (Drifter 16') "Rincon Maiden" Barry. I have included another picture of her just before putting in the river. It may give your readers a better idea of her lines. The original sheer clamps came just above her name, so that will give you an idea of how radical the raise in the bow was. I am really excited about you putting her in the web letter (WebLetter 13). Thanks. I don't mind if you use my e-mail address so others can write me for more info. Thanks again, Bo Cole
1 Photos
thumbs pic22 Drifter Design
To Glen-L
I enjoyed building my 16' Drifter. The plans were easy to understand and straight forward. This should make a fine fishing boat. - 3 1/2 mos. to complete. Only one problem, now I want to build a 20' boat! Guess you can't have a big enough boat.
Greg Frickey Downey, CA 90240
1 Photos
thumbs drifter parrott9 Drifter Design
I built this Drifter from your plans last winter. It was built using "regular plywood" from Home Depot and poplar and white pine for the battens, rub rails, seats, and trim. It's coated with epoxy. The oars were carved from 2x12" fir boards. For the maiden voyage, three of us went on a 4 day float/camping trip down the Yellowstone River in Montana. The boat performed better than I could have dreamed. We went through some pretty serious rapids (even had water coming over the bow a few times) with a very heavy load and had no problems at all. I love it!
12 Photos
