Glen-L 25 Design
Glen L 25 Solo by J.W. Kim
Glen-L 25 Solo by J.W. Kim, Geonaai-do, South Korea April 24, 2009 Glen-L 25 building has been ongoing. Completed the hull, righting up, ballast & centerboard attaching and began interior joinery work.
Glen-L 25 by David Sauer,  Sun Prairie, WI
<p>August 28, 1999 </p><p> Glen-L Marine Designs 9152 Rosecrans Ave. Bellflower, CA 90706-2138 </p><p> Dear Friends </p><p> I recently completed (If one ever really completes a larger boat) your Glen-L 25 Duet. I have included some pictures that you can use for what ever you like. I made a few modifications because of the intended use. Since I do lots of boating on the upper Mississippi where sailing is impractical and since I will motor a lot, I put on two kick up rudders, each as deep as the retracted center board and put the motor in the center. I also added a small hatch on the back of the aft cabin to more easily access the motor. The mast is a shortened E scow mast that I got free.</p>
Glen-L 25 by Dave Beem
<p>Well here is the ballast keel under construction working with 10 ga steel is not to easy but can be done.</p>
Glen-L 25 by Thomas I. Stuart, Cambridge, Ontario, Canada
<p> Updated November 2013 </p><p> June 2011 </p><p> Here are some pictures updating a Glen-L 25 project I started last summer. I purchased the plans around 1980 and am just now getting started. Hope to have the plywood and fiberglassing done this year then turning it over in the fall. More photos to come as I complete the project .</p>
