Mackinaw Design
  • Zip by Ron Salvino
Mackinaw-AL by Rob Landsman, Sooke, BC Canada
My friend Ken and I started the boat two weeks after my son was born at my father in laws place Campbell cove Maritime in Sooke BC. Ken is a metal boat builder, he told me about you. I picked the Mackinaw design because I want a fishing and camping boat. Ken made a cardboard model to work from along with the blue prints.The hull is 1/4\", sides are 3/16\" and the cabin is 1/8\". The boat will be powered by a 300hp Evinrude E tec. I will have the boat Cabin interior foam sprayed soon. After that I will start on the wood work inside.
5 Responses to Mackinaw Design
  1. Charlie says:
    What is the minimum HP (outboard) needed to get the 19′ version in wood to plane out? Since this is the same hull used in several boat designs then, I assume, the hull weight is about 1200lbs for the wooden 19 footer.
  2. Nikki Tan says:
    what about salt water, are they lighter than fiberfglass
  3. Nikki Tan says:
    What about the rust factor ? Mostly in salt water, Is there a version that uses less HP?
Leave a Reply
