Raven Design
Raven by J. Pete VanVorst, Fort Pierce, Florida
<p> June 2013 </p><p> I bought the Glen-L Frame Kit for the Raven in the 1980\'s, then added an additional aft frame and a bridge, resulting in a boat 26 ft. long by 8 ft. beam. </p><p> With a 115HP Johnson on it - it flew! Did Cape Cod & the Islands. </p><p> Thanks for all the happiness! </p><p> <em><font color=\"maroon\"><font size=\"-1\">EDITOR\'S NOTE: While some Glen-L designs can be lengthened or shortened by up to 10% of the design specifications by equally increasing the distance between frames, Glen-L does NOT recommend changing the designed beam width or adding additional frames of any boat, as this may result in compromises in performance, stability and safety. </font> </font></em></p>
Leave a Reply
